mattjohndavies
- Joined
- Feb 4, 2013
- Messages
- 42
- Points
- 12
Hi all,
Only just signed up to the forum but long time reader. I have a Punto Mk2 1.2 8v 5dr, 2001.
Tonight I noticed a slightly strange issue with my brakes when I parked on a slope. I had pressed the footbrake just enough to stop the car, and when I applied the handbrake, the pedal suddenly pressed down further without more pressure being applied to the footbrake. It was like only the rear drum brakes were being engaged by the footbrake and when I pulled the handbrake on and took the pressure from the pedal, the pedal slipped down until the front brakes engaged.
I haven't had a chance to check anything out yet, but I can't see it being an issue with either the master or slave cylinders as, correct me if I'm wrong, any issue with these affect the front brakes as well as each slave cylinder controls an opposite front and rear brake. My ideas would be bleeding the brakes to check no air is present in the front brakes, or maybe the brake proportioning valves, although I wouldn't imagine both would go (there's one on each slave cylinder correct?).
Any ideas would be highly appreciated as I am slightly concerned that if this got worse and the brakes were applied heavily to the rear with none at the front it could cause locking of the rear wheels and an ensuing accident.
Many Thanks
Matt
Many Thanks
Matt
