FindAName
Hi all
just reinstated a 2010 fiat 500 1.2 which had been sitting non running for a while (think 6-12 months).
Car has gone through its MOT with a few advisories and is now being driven my my daughter on her L plates and she is loving it.
Few niggles are now coming out the wood work (I was warned )
Clunks from front end on left hand side; on hitting potholes/bumps in the road (plenty of them out on the Fenland roads we drive) or on speed bumps. Have looked around on forums for common causes are the usual suspects. Have ordered new drop links first see if that cures it after if not I was going to look at top mounts. I haven't had a chance to put the car up on stands and check so was going more by process of elimination to begin with and drop links were £20 for the pair.
Air con seems to be non existent, both in terms of cold air and the light on the knob giving any indication if it is on or not. Can hear the valves shutting and compressor spinning so from that I have worked out when it is on or off. When it is on and the fan speed is turned down to 0 (from full) the is a tinny rattling type sound.
Hopefully I will get time at the weekend to check the pressure and I have a little bit of gas left to try and re pressure it to see if that helps.
Last thing is when we were bleeding the cooling system the top bleed screw snapped off; seen a few posts on it and some people have had success drilling it and then putting a new screw in. other than that it does seem to be a bit of a pig of a job.
Thanks all in advance for any assistance
Mike
- Any thoughts on what to do after the drop links, top mounts or something else?
- Any thoughts on the culprit of the sound?
- Anyone have a link or part number for that screw ?
Mike
