martin123 Patron member Joined Jul 4, 2008 Messages 11 Points 6 Jan 4, 2009 #1 the main centre system ilumination has gone, is it a bulb or a led,anyone done this job
J john55 Established member Joined Jan 22, 2008 Messages 1,129 Points 189 Location Tropical paradise -Luton Jan 5, 2009 #2 Are you talking about the button or display illumination?
Y yellowstilo Patron member Joined May 5, 2006 Messages 894 Points 214 Jan 5, 2009 #3 as far as i know there is a luminescent tube behind the screen with an inverter to generate the high voltage.
J john55 Established member Joined Jan 22, 2008 Messages 1,129 Points 189 Location Tropical paradise -Luton Jan 6, 2009 #4 yellowstilo said: as far as i know there is a luminescent tube behind the screen with an inverter to generate the high voltage. Click to expand... That's right. The most common problem is the power supply to the inverters ribbon cable coming out of its connector. Simply take the front off and push it back in. Next most common fault is a failed tube.
