- Joined
- Aug 25, 2011
- Messages
- 178
- Points
- 85
So the other half's stilo sat for a week (holiday, so no to-fro work), and now it wont start. We initially thought the battery was weak/dying, and indeed it read ~11.7v, which is lowish. Put it on the trickle charger for the night to bring it up to ~12.3v, still no start. Hooked up my alfa GT with jump leads, still no start, started the GT, still no start on the Stilo despite reading 13.7v on the terminals (being charged by the alfa). Had the alfa idling for ~15 mins to charge the Stilo a bit more, still no start...
With the extra power it does spin the engine better, rev-wise it sounds like it should be OK.
Next we checked:
- Spark, took a coil/plug out and witnessed it sparking when starting, so that looks OK
- Fuel, after a longish attempt at starting, some fuel smell comes out the exhaust. The fuel pump under the back seat primes, and spraying some WD40 into the throttle body failed to produce any other result
- ECU, had the ecu out and checked the pins, didnt see any damage on any solder joints and all pins felt securely in place.
Car isnt throwing any engine management codes currently, it has in the past, the most recent code was a catalyst efficiency code, so it seems unrelated.
Father in law suggested it might be the cam angle sensor, but from what i can find that is behind a cam pully, which would mean timing belt off, meaning it isnt exactly an easy thing to check.
Any tips/pointers/things ive missed?
Next we checked:
