- Joined
- May 10, 2010
- Messages
- 2,669
- Points
- 800
The boy's 2012 Pop has developed steering issue.
Nearside front tyres outer edge has worn out and there's a knock and slight bit of play in the steering when you rock it.
The offside tyre isn't as bad, but it looks like it might be on a similar path.
It had 4 new tyres and the tracking checked for it's last MOT back it September and the boys says it's been driving well until recently, when the steering went a bit tuggy to one side.
I've had a bit of a quick poke around and can't feel anything in the track rod ends, inner tie rods or bottom ball joints, but you can feel the knock in the road wheel.
It drives smooth enough on a good road, but there's a little knocky/rumbly noise and slight loose feeling under the front when I drive it over some brick paving.
There's something loose/slack under there and I can't quite pinpoint it.
