I've got an 06 plate 1.9 sporting, and last monday when coming home from a course, was coming up the valley on the dual carriageway the car began overheating. The temp guage started rising to the next mark after the half way point it normally stays at, and kept rising slowly as long as the car was driving under load. Foot of the throttle and the guage would slowly drop back down. It eventually got to the red and on the displal turn off engine showed. I stopped and checked the water, and it needed topping up. Topped it up with about 600ml and came home.
Took it to the local garage, and the mechanic stuck some liquid in that fills any leaks in the rad?? Water level has stayed the same since, but the car is still overheating.
After the car has been running for approx 15 min, the guage will start to rise slightly, and even under light driving, will stay high. Before the temp starts rising, i can hear the fan running after the car only beign driven for about 10 min. When the car is left to idle, the guage doesnt move at all. On a couple of occasions on the way home today after taking it for a little run it got to the red light and had to stop the car.
Been back to the mechanic and he said the possible issue could be with either the thermostat, the water pump, or maybe the radiator.
Has anyone got any ideas as to the more probable cause? The timing belt is being done early in the week, as it needs doing anyway, and I'm away with work so dont need the car. Are there specific symptoms for any of the items the mechanic suspects?
Any help is very gratefully appreciated.
Paul
Paul
