Technical Help with codes
Rubensilva666
Hi guys.
So today i put my multiecuscan to work. ( full version)
So this are the codes i got.
Any help is welcome.
And the 3 codes in a roll are from the dualogic gearbox...only.
Its a 1.2 8v from 2010.
Looks like has been neglected for some time. Found so many bad things with it. But dont wanna sell it as my wife just loves it.
Any active issues with the vehicle?
If not I’d reset codes and monitor. They’re all potentially phantom errors which could be caused by low battery voltage potentially.
Sometimes it jumps to neutral.
But I'm still waiting to do a oil check on the robot. Unfortunatly I need to replace the daylights as the old owners did not had any care,and drove it in the rain without mudgards and screwd up the eletronics. All needs replacement.
I have made a couple of videos of the engine working idle and from exhaust. There is clearly something wrong...
This last 2 videos looks like the car is idling up and down, but not enough to see the rotation on dash
Hi, have you sorted it? I have similar behaviour of the engine. I have replaced spark plugs - the same. Now order new coil pack and HV leads - will see.
Mine is still the same. I even changed the trolley body with no luck. I have multiecuscan and can't find anything. Can be a vacuum leak, but belive it is something mechanical, and not electrical. I'm doing 60.1 mpg, what I think it's alright. Will see as I have mot soon.
Can be the breeding pipes under the cover also I have bought broken.
