S shuggs Patron member Joined Nov 10, 2008 Messages 94 Points 35 Location Fife Aug 19, 2013 #1 Am needing to get another headlight for daughters car, after being at breakers for spring last time know there are different figments big question is bulb connections - are they all the same?
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Aug 19, 2013 #2 Headlights no the mk2 had a mix and match Some people had h7 bulbs Some people had h1's Some accident repaired or even out factory to believe had 1 of each! So check both, and adjust from there Ziggy
OP OP S shuggs Patron member Joined Nov 10, 2008 Messages 94 Points 35 Location Fife Aug 20, 2013 #3 So if there are different lights would the light connections be different too? Looks like I will be going for a pair then
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Aug 20, 2013 #4 shuggs said: So if there are different lights would the light connections be different too? Looks like I will be going for a pair then Click to expand... h7 uses a bulb like this and a connector like this H1 is like this + connector# H1 basically use spade terminals by looks of it Ziggy
