During a drive, a hose blew, the one on thermostat.
Stuck thermostat, so replaced it, got new hose, fits from clio 1.2, as original was unobtainable.
Before it blew, had occasional heat gauge fluctuations, which I now know could indicate stuck thermostat.
This overheating behaviour still proceeds, but is not as profound.
I do however quickly loose all the expansion chamber coolant. I don't know if leakage continues, after chamber is empty, but it seems not, as I can always pour in exactly 2 litres of fluid to top it off.
Oil is OK on the stick, no milk, also oil filler cap is OK.
No smoke, car runs normally and starts OK, cold or hot, and is as potent as ever. No sweet exhaust smell.
I would however like to check the sparkplugs, but don't even know which socket is for removing them, 14, 16mm? Dont have it, need to buy.
I do notice, that every time I top up the coolant, there is a leak below the car, but not a big amount, like 1/5 liter maybe (2dcl).
This happens only during first night, and not again untill next refill.
Very hard to pinpoint location, as all critical areas are dry (hoses, radiator..), and engine block is partially wet from minor oil leakages.
Its a closed cooling system, so its a bit hard to check with single cylinder plug compression, indicating splashing of coolant at the radiator cap.
