scimitargtc
- Joined
- Jul 6, 2008
- Messages
- 102
- Points
- 31
04 rhd 2.0jtd dynamic 89k full FSH - replaced both rear handbrake cables (inner shrouds fouling on the outer sheath preventing full release of the pads when taking off the handbrake - added a spring to assist the 'spring back' mechanism ie the rubber metal bracket where the cables all meet and this works but the caliper handbrake operating levers move different amounts n/s approx 20mm o/s 2-3mm Q - are the handbrake levers at the calipers adjustable?? There is a nut that secures the lever but before I take off the nut and end up with a 'mess' does anyone know if they can be adjusted before I fork out £61 per side for exchange calipers??? As history I had an Tempra 2.0ieSX SW from new in 1992 and her handbrake was always unbalanced until about 2 months before I sold her
cry
- took calipers apart to find there was a shim aka a steel washer! that operated the handbrake operating lever adding a thicker washer from my tool box immediately sorted what had always been a problematical handbrake hence my train of thought.....:bang:
