PC Vehicle Movements
This info is for whine0 message in box is full i didn't fancy typing all this info out again lol
PO402-61 Air Quantity Control PO401-61 High Pressure EGR Valve Blocked
engine speed 2326 rpm 1805 rpm
bat v 14.377v 14.406
intake air quantity 776.5 mg/i 694.5 mg/i
desired air intake quantity 2951.5 mg/i 2481.0 mg/i
engine temp 84c 60.5 c
low pressure egr position 4.59mm 4.72 mm
low pressure egr target position 4.69mm 4.82 mm
boost pressure 1439 mbar 1258 mbar
desired egr position 0,000mm 0.000 mm
actual egr posistion -0.018 mm 0.021 mm
air temp boost manifold 26.00 c 20.0 c
total fuel quantity 31.92 mm/i 33.32 mm/i
throttle position 11% 11.94 %
air quantity control Disabled Disabled
Particle filter regen OFF OFF
EGR éxchanger exclusion Valve OFF OFF
1st set of readings are for PO402
2nd are for PO401
2nd are for PO401
