BeaglePup150
The temp gauge suddenly moved from normal to the top of scale. On tickover the fan started, none of this has happened before.
I checked coolant a little low, found two bleed valves on a pipe near the rh side fo the rad, when I opened them a fine vapour; a mix of air and coolant came out under pressure.
It seems to be ok now but what could have caused it?
also what is the correct coolant? I am considering draining and replacing the system,
and are there any other bleed valves on the cooling system?
If there is a small leak, should I use radweld for something similar or should I just use it anyway?
Terry
Terry
