Hi all,
Recently have been experiencing loss of power with my Bravo 1.9 MJet 150 bph. It is happening intermittently but normally happens on a stretch of road (which is hilly) on the way home from work in the afternoon when I am doing about 50-60 mph. When the revs drop to about 1900rpm I suddenly have no throttle response and start to lose speed. I then plant the throttle and about 10-20 seconds later, after the revs have ever so slowly climbed to about 2900 rpm and I am doing about 30mph, the car suddenly bursts in to life.
It seems to be happening more frequently in the warmer weather.
It has also occurred when I have stopped at a junction, after a stretch of national speed limit road, pulled away fine in 1st gear then changed to second and the car seems to go into limp mode. On some occasions had to put the hazards on and find somewhere to pull over, plant the throttle and wait 20 seconds or so for the revs to build then whoosh!
Do you think what I am experiencing is a sticky EGR or MAF problem? Or something else?
Car has been on diagnostics and no fault codes. There are also no warning lights.
In between the losses of power it still seems to be running ok with normal amount of torque etc. MPG is down. I would say the car is running a little lumpy.
Car has recently been serviced with new air, fuel, oil filters and oil change etc. Passed the MOT and no emission issues.
Any advice welcome.
Ed
Any advice welcome.
Ed
