On an 06 1.9 6sp
I've been at it for days on and off and just can't get the o/s shaft out the gearbox because I'm sure the the bearing is "welded" inside the alloy mounting carrier.
If I can put a blow torch on it will I ruin the bearing, if not once heated how will it come out as there's still general corrosion on the shaft from the bearing to the gearbox therefore when getting put pulled out, the corrosion won't slide out through the bearing if you see what I mean.
I've honestly no idea how this is going to come and seriously thinking about selling for spares ect.
