Open it up and make sure all the ribbon cables are connected inside. Some of them can work slightly loose.
Do the buttons illuminate or anything?
If that doesnt work, or you are not confident at taking it apart, send it to me and I can take a look at it. I have repaired quite a few of these now.
Hello John,
i have a CN+ with a half-working screen - only the left part of the screen is displayed normally, the right half is gray without any info shown.
My first thought was the ribbon cables, tried to wiggle them but no result.
Does this sound familiar to you ?
Thanks for your help,
yellowstilo
Never seen that fault before.Hello John,
yellowstilo
Only time I have seen the fuse blow is in my car when the previous owner connected the battery the wrong way round. Changed the fuse and CN+ lived again.maybe too simple but did you check the fuse on the back of the CN+ ?
I would think it is something in the display drive electronics, on the display itself. Try reseating the connectors or moving the PCB to see if it has a bad connection somewhere.
Hello John,
thank you for your offer , however i'm not sure if it's possible to separate and refit the glass from the electronics - the glass is kind of spot-soldered to the circuit board with flexi-foil on a very tiny scale......
If you think it is doable to change the glass (or actual screen??) please send me a price quote for shipping the part to the Netherlands.
yellowstilo
I have one.
The glass is cracked, but the electronics part should still be OK.
I will test it before sending it if you want it.
