mudwuk
Had the timing belt changed on my 1.4 16v Eleganza about four months ago. Ever since I've had a check engine light but with no obvious impact on performance. The garage has had a look and says the error code is unrelated to the work on the timing belt and would require the ECU to be replaced, something they said could cost £400.
I've got a OBDII code reader, which says the error code is P2226. I've looked this up and the description says "Barometric Pressure Sensor "A" Circuit". Does anyone know what this relates to? Is this talking about the MAP sensor?
Any advice would be much appreciated.
