Hello Friends,
I got new problem with my Brava. There are no spark, so I am not able to start the car. There are no problem with ignition coil, problem is elsewhere.
One strange thing, what happened together: when I turn on the ignition, main cooler fan starting to rotate at full speed and stops when I turn of the ignition (car is absolutely cold). I am not sure, that both problems are relative, but it happened in same time.
Where can be a problem? Something with ECU. I tried to connect laptop to 3pin connector, but with no luck (no response from ECU). I have other Brava (1997 1.4) and can connect to its ECU with no problems.
And second question: does main fan working only with ignition on Brava 1996 1.6? When my other Brava heating, it working with or without ignition.
Thank You
Thank You
