In answer to your original question , if you have a sofim engine , which i have no reason to suspect you don't , then the answer is yes . The water pump is part of the engine mount , and also holds the cambelt tensioner , so it is also a good opportunity to replace the cambelt at the same time , as the timing is also disturbed . The job is not difficult , but is time consuming , and also requires the removal of the alternator to improve access . There is a steel pipe behind the pump , that requires two nuts to be removed . I don't know about the mileage limit , but mine was 21 years old when i replaced it . Year 2000 , 2.8 idtd , left hook , Hymer 584 . I would advise removal of the pump pulley , before attempting to remove the pump itself , space is an issue . The pump is held in place by 4 bolts of dubious quality , so i would also strongly advise replacement of those at the same time . If the pump has not been replaced before , be careful . I pumped easing fluid on them , then bounced the struggle bar to release the tension . But here i had both the bumper , and intercooler removed , so good access from the front . Just for information , the struggle bar was nearly three feet long . I then supported the engine with two jacks , plus blocks to remove the pump . Support only the outer edge not the centre of the sump , this is only tin , and will collapse .
I rebuilt my entire cooling system , with quite literally only 3 of the original parts remaining , the engine , and both cooling fans . This took close on 13 months due to parts issues , coming from all over the EU , including Poland . There shouldn't be any problems with just a water pump , they are available in this country , from Coastal Motorhomes . I would also advise you consider replacing the steel pipe behind the block at the same time . It runs from the water pump to the thermostat housing , and i've heard of several on this age van failing . They are also available in this country , from the same place . Use the thin gasket supplied , not the thick one . The pipe costs around 20 quid , where an original from Fiat cost close on 150 (just don't ask me how i know okay) .
Now i will be honest , they are a bugger to remove and install , as space is a major issue . Mine came out via the battery tray area (which was also removed) , and comically replaced via the thermostat side . The problem being it slips under the turbo manifold , just above the blower itself . I would strongly advise placing this pipe in place , before refitting the new pump . I would guess this was where i went wrong , i fitted the pump first . As a pure guide , the pipe should take around twenty minutes , and depending on what you remove , the pump itself would be somewhere between 4 , and 8 hours . I can't really estimate anything better , as my vehicle was (and still is) having some quite major overhaul work done at the time , and access was excellent due to other parts already being removed . It's been off the road for close on three years now , and hopeful will return later this year , with many completely new , and fully overhauled systems.
