So looking at a friends jdt 1.9. It was sounding like a bag of nails was let loose.
Was locking engine by hand but running on its own when started, yes I know bad idea to run it, but any damage would have already been done.
Took injectors out and cylinder closest to cam pulley, either one or four, not familiar with these so not sure what way round they have it. And it has oil in cylinder. Only one all other bores are clear.
So question, head, valves seals, or is there another reason. Not suspecting turbo as its only one bore.
Still locks when turned by hand with injectors out so I'm guessing its bent a valve, cam belt and all other timing parts are ok. Car was stopped very quickly after noise and was turned over for 2 seconds to hear noise.
I'm guessing the hydro lock isn't that bad as nothing like a belt or cam has been snapped.
I'm also assuming the oil is coming from top as when pressure applied by hand there is no give or slow release of pressure if the rings or bore was damaged.
So does what I'm saying make any sense to anyone? Can anyone help in telling me if this has been known before? Done a search but nothing has turned up.
The strange part is that the oil in bore is clean, not black like the rest of it but new looking oil. I'm going to find out if he has topped up with oil or noticed a drop in oil. But saying this and thinking out loud if the valve seals had gone would topping up the oil let clean oil in cylinder. But I'm sure it would have been pushed out exhaust by now.
