Thread Tools
Old 4 Weeks Ago   #1
Punto engine swap issues 😣
Hi guys , I've done countless hours of research on this to no avail so thought I'd ask here,
I have a 2002 1.2 8v mk2 punto but the head gasket blew, so I switched the engine for another I found on eBay.
Turns out I bought a 2006 engine as I was only looking at engine codes when purchasing, only differences were the be fine mount and a different map sensor plug so we switched the original inlet manifold onto the newer engine,
Other than that everything else matched up and works fantastic
Only issue is that the engine struggles to start hot , will take 3 to 5 attempts to 're start and stinks of fuel
Also it's liable to cut out if it's been idling a while when hot
So far we've tested or changed the following
Plugs
Leeds
Coil.packs
Cam sensor
Crank sensor
But no joy , we opened it up.today to look at the valve clearances but the head is completely different to what we expected
I know I'm starting to clutch at straws but I feel 5he ecu may be to blame as there's a few small differences between the engines and that may be the issue ?
Has anyone any experience with this issue ?
Thanks in advance
smateas is offline Reply With Quote Quote
Thread Tools
(G) punto engine swap. skyteam Punto (Mk2/2b) 2 09-08-2010 11:36
(T) punto engine swap.. nocturnal warrior Punto (Mk2/2b) 2 20-10-2008 22:59
(T) 1.2 punto engine swap keithjones1400 Punto (Mk2/2b) 2 08-10-2008 07:25
(T) Punto engine swap ToonArmy Punto (Mk1) 11 23-09-2005 11:49
(T) Punto Engine Swap! welshboy84 Punto (Mk2/2b) 5 03-12-2004 18:53
