Lamps by Post - For all your lighting needs
Thread Tools
Old 14-07-2017   #1
Sweden
Need help about injector seating with notch
Hello guys, im in big trouble and getting grey hair 😭I noticed the injector was leaking, and i bought new washers, but the old one was a pain in the a** to get out it took 3 hours and when i was finished i had made a big notch 2-3mm deep in the injector seating, so i cant get it to seal i was so stupid to hit it with the screwdriver what do i do now? Can i buy a injector seat cutting tool, and cut until its all nice again and then maybe fit 2 washers to compensate for the missing aluminum?
Thanks in advance.
Moffe is offline Reply With Quote Quote
Old 14-07-2017   #2
Sweden
Re: Need help about injector seating with notch
Oh forgot, the car is a Fiat stilo 1.9jtd 140hp
Old 27-07-2017   #3
Moderator
Peter Pick-Up's Avatar
Peter Pick-Up has donated!
Netherlands
Those kits are available on Ebay.
Did not need to use one, so can't comment on them.
I would NOT fit two washers.
Be carefull not to drop anything into the cilinder, though.
Next time when removing a sticky injector: spray it with carburetor cleaner, the gunk and debris will disolve in minutes, and the injector comes out easily.
One little trick: when everything fails, and the injector is still stuck, loosen the clampbolt 1-2 turns, and start the engine briefly, the compressoin will push the injector out.
Just replaced the copper seal on one of the injectors on my 2004 Alfa GT jtd with 240.000 mls, (380.000km's) came out easily, work was done within one hour....
Peter Pick-Up is offline Reply With Quote Quote
Thread Tools
Ducato Seating Morph65 Members Motors 1 09-10-2016 19:07
(S) Seating wellbeloved747 Grande Punto 1 12-11-2014 09:29
(G) Seating arrangements firstcar-Y10 Panda (Classic) 9 13-09-2011 16:48
(T) Were's my notch... littletav Cinquecento / Seicento 3 25-02-2010 23:16
(G) seating Eggy-88 Cinquecento / Seicento 3 01-10-2007 22:12
