Thread Tools
Old 07-04-2017   #1
I:9 jtd.
Hi folk's I've had a Sedici now for five weeks,bought from the guy who has serviced my cars for years, now it was a cat D needing a new bumper only
which along with servicing and fitting a new EGR valve was all sorted for me
but on the way home from work after a few days and about 150 miles
worth of use there was a bit of a growl and what sounded like spluttering
which didn't seem to be engine connected and there was no change in performance or warning lights flashing so with a mile to get home I risked it
and as I climbed the hilll for home it went never to return but personally since
then I think the car is more responsive and smoother and I definitely seem to
feel the turbo kick so all being well I've enjoyed the drive but yesterday after
ten minutes of stop start traffic a mile after getting moving as I pulled away from the lights a similar noise again if a bit higher pitched no performance issues
or warning lights, this time I was a mile from work I drove on it disappeared as I
pulled in that said the fan was going full belt for a couple of minutes after switch
off today the car is sweet as a nut,just wondering if they are issues with the car standing for a few months not in use.
stevej60 is offline Reply With Quote Quote
Old 07-04-2017   #2
varesecrazy has donated!
Quote Originally Posted by stevej60 View Post
Hi. Is it DPF equipped..??
Fan running is typical or a REGEN taking place
Likes stevej60 liked this post
varesecrazy is online now Reply With Quote Quote
Old 07-04-2017   #3
Re: I:9 jtd.
I've no idea sorry,Regen?
Old 07-04-2017   #4
Re: I:9 jtd.
sorry no idea regen?
Old 08-04-2017   #5
Re: I:9 jtd.
hi,
the Diesel Particulate filter.. it's a "soot-trap" in the exhaust, and to clean / purge itself it uses extreme heat to burn the soot,
a running cooling fan is a common indication it's that
the vehicle is performing a "regeneration - cycle".
charlie - Oxford
Old 08-04-2017   #6
Re: I:9 jtd.
Thank's Charlie,I,ve now read up on the subject so a little wiser what to look out for.
the car is still fine spoke to my guy and he is aware this has happened will see if I get a
repeat.
Old 16-04-2017   #7
Re: I:9 jtd.
Well the problem re-surfaced today and the answer! the noise was the right hand
fan,the bottom arm is bent so when the fan has been kicking in because it is out of
line it has been scraping the rear of the radiator and managed over the last few
weeks to wear away the main rubber radiator pipe which after today,s occurence
has split thankfully just as I arrived home so anew hose and a straightening of the
arm and all should be well!
Old 19-04-2017   #8
Re: I:9 jtd.
Car returned today new hose fitted and fan housing,no charge and running well
so back to enjoying being a Fiat owner again!
Thread Tools
(T) Whats the engine difference between 1.9 elx jtd (mk2) and 1.9 dynamic jtd (mk2b)? Johnboi94 Punto (Mk2/2b) 0 11-09-2014 01:07
2001-2007 Stilo JTD gearbox onto 2002 Multipla JTD Smurftipla Tech Talk 0 30-08-2013 14:03
(T) Multipla JTD 1.9 JTD - Engine cuts out and injector light illuminates. Heaven43 Multipla 4 07-07-2011 18:02
Will a doblo 2005 JTD engine fit in a bravo 2001 JTD? (FAO Tom?) Stu FIAT Boo Archives 7 08-11-2007 23:33
(T) After Bravo JTD non-runner or JTD complete wiring harness for project... JTD Lover Bravo / Brava 2 07-12-2005 17:42
