FIAT Auto Specialist Team
Thread Tools
Old 04-03-2017   #1
1.9 JTDM trouble starting - Please help
I've just purchased a 1.9 grande punto, 1.9 jtdm
Anyway it has trouble starting up from both cold & hot (So assume its not glow plugs)
No fault codes in ECU.
Runs absolutely fine once started, no misfire etc.
It just takes about 45 seconds to fire up.
It has full Fiat service History and cam belt has been changed, only about 80k miles.
what's your thoughts?
Crankshaft sensor? (Although would this cause problems whilst running?)
Test injectors - (leak off test?)
No sure where to start
thunnisett is offline Reply With Quote Quote
Old 04-03-2017   #2
varesecrazy has donated!
Re: 1.9 JTDM trouble starting - Please help
Hi, and welcome,
ok - so no codes,
does it smoke on start-up ?
if no smoke then it's burning cleanly..NOT the plugs.
have you cycled the plugs? (to build heat).. good diagnostic tool
after that you'd want to look at what the ECU's seeing..,
Charlie - Oxford
Old 04-03-2017   #3
Hi
Thanks for quick reply.
No smoke. Drives absolutely lovely.
Would the glow plugs be a possible cause if it still has trouble starting after running for 30 mins +?
How do I do the ecu test?
Old 05-03-2017   #4
Quote Originally Posted by thunnisett View Post
Hi
the basic theory is that COMPRESSION is enough to get diesel burning = the engine running,
glow plugs just add local HEAT..to aid the initial burning
once the engine is WARM thay should do very little,
Diagnostics;
plug in a device to the OBD port - like when you scanned for codes,
then look up all of the temperature sensor readings,
if it thinks it's -40'C it'll do odd things..for example
we tend to use MultiECUScan,
I'll give a link to similar Multijet posts,
http://www.fiatforum.com/grande-punt...se-help-4.html
charlie
Likes thunnisett liked this post
Old 05-03-2017   #5
Thanks Charlie
I'll try that
Also on that tread its suggested to test the battery startup crank voltage. I'll give that ago as well
Old 05-03-2017   #6
the engine relies on cranking speed to build pressure in the fuel rail..
if too low it doesn't inject.. and you say it doesn't smoke when it eventually starts - this all makes sense,
Charlie
Old 05-03-2017   #7
Moderator
Peter Pick-Up's Avatar
Peter Pick-Up has donated!
Netherlands
JTD engines need the glowplugs even when hot..
My bet would be glowplug(s).
Assuming the battery is OK.
Peter Pick-Up is offline Reply With Quote Quote
Old 05-03-2017   #8
Quote Originally Posted by Peter Pick-Up View Post
but a couple of COLD cylinders..that would normally make "smoke" from unburnt fuel.. O.P. says it clean
Old 05-03-2017   #9
Moderator
Netherlands
It should have give a code, right.
Lot's of things can be bad, f.i. bad/worn injectionpump, but that should trigger a code too....??
Old 05-03-2017   #10
That's why I'm stumped. No codes and I'm using an expensive CReader professional machine.
I'm hoping it's the battery.
I'll test the battery in the week as I need to get a new injector T-Piece as broke one
Old 05-03-2017   #11
Moderator
Netherlands
If the battery is able to crank for 45 seconds, it'll be all right...
Old 05-03-2017   #12
so where are you / the car based..??
Old 05-03-2017   #13
The car on my drive but when I was checking the injectors one of the T-Pieces must have been brittle and snapped. Now when I start the car it pisses diesel everywhere.
Just waiting for a new injector T-Piece to arrive and then I can test the battery then move into other things.
I'm in East Sussex- St leonards
Old 12-03-2017   #14
Cold crank on battery is around 10.5 so think the battery is ok
I noticed today the starter motor was turning slowly on a few attempts so wondering if this is the cause.
Have ordered a new one.
Any instructions/ guides how to fit? And is it easy for a noob? Or shall I get a mechanic? (Approx what labour time is it)
1.9 d, 120 bhp
Old 18-03-2017   #15
Starter motor changed but made no difference.
Have the injectors tested Monday (leak back test)
Thread Tools
(T) 2008 1.6 JTDM Starting Woes Most Easterly Pandas Bravo 3 28-12-2013 13:59
(T) Trouble Starting Funkstar De Luxe Barchetta 16 13-02-2009 10:09
(G) Trouble Starting ap07aaa Bravo 13 18-12-2008 18:21
(T) Trouble starting!!!!! Astle10 Punto (Mk2/2b) 1 30-11-2008 23:39
(T) trouble starting alanstalin Punto (Mk2/2b) 4 17-08-2008 15:14
