BoardinBob
Posted this in the doblo specific forum but didn't get any replies so hopefully a wider audience can help.
A few issues that may or may not be related
Stop Start:
During the summer, when I have the heaters in the van turned all the way down and the air con on, the Stop Start system works perfectly. However in winter when I have the heater turned up, I often get a warning that the Stop Start system has failed and I have to check the engine. In addition, the water temp gauge suddenly falls to zero. It'll creep back up now and again then fall away suddenly. If it stays up constantly then it sits lower than it normally would if the Stop Start was working and the air from the vents doesn't feel as hot on the maximum setting.
I've checked with Multi ECU Scan and I'm not seeing any errors stored. Very strange. I'm guessing it's something to do with a temp sensor or the thermostat????
Dash Warning Lights:
This just happened fairly recently. There are two lights very faintly illuminated on the dash. One appears to be the DPF light and the other is an image of the van with the bonnet open and it's red. Again they are just very faintly illuminated. When I turn the ignition on the DPF light properly fully illuminates for a second then goes to this faint illumination and the other light is also showing faintly.
Again no errors showing in ECU Scan. Interestingly I don't need to put the key in the ignition to get them to light up. Simply unlocking the doors and opening them gets them to light up so I'm guessing it's a short circuit somewhere??? Any ideas where to start looking for that :bang:
Stop Start:
