Hello.
After researching 67.8% of internet I have decided to write a post. Yes.
My baby Bravo 1.9 Mjet has died.
What happened you ask? Well, a few things.
Put it into reverse at home parking, i got information about ASR/ESP being not available, what quicky followed by info about faulty lights - corresponding light on dashoboard lit.
So I parked. So I switched the ignition OFF and back ON. And this time discovered the brake light does not work at all. The brake pedal is hard, I mean like reeeeaaaaally hard. And - clocks died. Neddles not moving, no backlight lights on it at all. The only working kight is from main lights. Also the mileage is displayed when I close the door so the clocks itself are fine I think.
As I was neeping through wast internet I have seen this ind of problem is quite common for whole range of Fiat cars - and in most cases caused by faulty brake light switch.
So replaced it - nothing better.
Replaced all light in rear cluster - nothing better.
Cleaned the ECU connetors, and left car unplugged on battery for 5 hours - still nothing.
Checked the battery - with engine not running it gives 12.7V, with running 13.8V - the conclusion is it is fine here.
Also read the faults codes of ECU, by ODB2 interface, this is completely clean.
I checked all the ABS sensors, electrical wise they are all identical so I recon the fault is not here.
I'm desperate now.
Any ideas ? Anyone came across similar issues?
Thank you in advance
Mariusz
I'm desperate now.
Mariusz
