What *real" experience does anybody have of Traction Plus?
This is a serious question as yesterday I had to be towed out of front nearside wheel stuck (or should I say spinning in) in boggy ground.
Background. Pull of the road to a dry/damp firm grass verge about 3 to 4 feet wide. O/S wheel 50%-75% on grass and 50%-25% on grass/gravel/tarmac edge. Front N/S wheel on soft water laded boggy surface.
When I went to pull away the N/S wheel just spun. There was no Anti-Slip attempt or flickering ASR light on dash. Then put into Traction Plus mode. Central display changed to the fancy 2 wheel info legend. Tried again but the N/S wheel just spun as before.
Tried a 2nd gear start, the same. Tried the old trick of gently pressing the pedal, same again. No flickering ASR light. No sound or juddering of the N/S brake being applied.
All very strange and rather embarrassing to be pull out by a Forestry Commission *Ford* 4x4 truck.
Today I ran a second test. In my 1in10 slopped drive I jacked up the N/S front wheel to release axle load and grip wheel grip. (safety note - jack orientated so it could roll forward). I then chocked the rear N/S wheel for both forward and reverse movement. Released the parking brake.
In both Sport mode and Auto mode the front N/S wheel just span. No indications on dash or evidence of juddering/braking. Then went into traction plus mode. The display started to show %drive to O/S wheel only, increasing to 100% but the N/S wheel just span.
This sound totally wrong and not as expected. Also no errors etc. reported by the car.
Two observations I have which could explain
1) This is a starting off issue limitation
2) The clutch pedal may not have been fully released and the system does not fully engage whilst clutch is not fully released?
If 2) is true then I should have just fully released and blasted out but I was already digging in so could have ended up with the sill on the ground!
