Water in the foot well
RC1407
Hi I'm new to the forum,
I've got a problem with my sisters car a fiat bravo '07 plate there is water coming out of the plastic leading to the passenger footwell the garage has looked and cannot find where it is coming from, the car isn't loosing any water from any of the system could it be the air con ? Has anyone has a similar problems and how did u fix it
Many thanks
RC
Likely problem will be the chamber below the wipers is full of rainwater because the drain tubes are blocked.
Lift the bonnet, and look into the space below the wipers. This allows air to enter the heater, usually without any rain getting in. Below this will be one or two drain tubes, which will be full of accumulated rotting leaves and the chamber is full of water, causing it to overflow into the heater and into the footwell. Clean out the drain tubes and allow the water to drain and all will be well.
If this isn't it, repost in the section for your model for more replies. Many Forum users only check their own model section.
Thank you, that's the first thing the garage checke.. I'll post this in the bravo section on the forum...
Thanks for your reply
