I have a problem with my Fiat Coupe 1.8 16V.
Problem is that engine stops on its own(just like you would turn key to off), completely randomly. For some reason it stops feeding fuel into engine. Sometimes it can be started again and sometimes it only spins, but fuel pump is working. It doesn't ignite. Injectors light turns on when engine dies.
I have already checked ECU for errors but there are none.
I've also checked the graph of lambda sensor and it looks normal to me.
I'm completely out of ideas what could be causing this, does anyone know ?
