Test the pedal response % with the ignition on but engine off. Should be very quick (you can hear it also moving, there should be no pauses, lag etc)
If it's not, remove completely the intake valve unit from the manifold (4 hex screws plus 4 the ecu) and clean it thoroughly with a spray. Clean map too, it will be covered with oil and dirt.
Then, make a throttle re-learn from multiescuscan.
