I see there's an unusual type of hose clip used on the radiator hoses on my '08 Bravo, it doesn't take a screwdriver or small socket like normal jubilee clips. There's a serrated steel band with some sort of clip locking it in place.
How do you guys deal with these clips? I'm thinking they're single use only and have to be cut off and then replaced with standard hose clips? If so, what do you use to cut them? don't want to damage the hoses or rad. pipe stubs. Anyone know what they're called and if they can be reused or if same exact type is available anywhere, any special tools needed?
(I put this question in this section because it probably applies to many other modern Fiat models.)
Thanks in advance for any info.
Al.
Al.
