Thread Tools
Old 04-07-2010   #1
Ohhh my, yes.
Garree001's Avatar
Garree001 has donated!
Cam belt or chain?
Just recently been looking at cars, and somehow come across debates on what's better: a cam belt, or cam chain?
What are the main advantages and disadvantages? What's the best?
Sad for wanting to find out, I know.
Quote Originally Posted by karbineftw View Post
It sure looks like it's erect from my angle.
Quote Originally Posted by volxstu View Post
Hit somebody at 50.. they die. Hit somebody at 60.. they die quicker.
Signature by alexh365
Garree001 is offline Reply With Quote Quote
Old 04-07-2010   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Cam belt or chain?
In general chains are more reliable and trouble free however this isn't always the case...ask a nissan micra owner.
Alot of cars also use a combination of belt and chain however if buying secondhand proof of a recent belt change is always a bonus (and belt changes can be very costly)
Old 05-07-2010   #3
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Bolivia
Chains often never need changing.
Mum's 1.0 Yaris is timing chain controlled and is a 2001 with 125k on the clock and chain hasn't ever been touched (as per service recomendation).
I think Panda MJ's have chain? But I've heard of one going at 70k.
I'd recomend Chain ftw if it won't ever require maintenance.
Failing that belt, as easier to change.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
2 White Classic Panda Selecta's, 1989 Panda 750L,
2013 Toyota Prius Plug-In & 2009 Panda Eleganza
Most Easterly Pandas is offline Reply With Quote Quote
Old 05-07-2010   #4
Chains are fitted during manufacturing and are generally a "fit and forget" for hopefully the life of the engine. Chain replacement can be expensive depending on the particular engine design. In the Hilman Imp engine (Coventry Climax engine based) then the chain is easily replaced by opening up the existing chain, attatching the new to to old and then hand cycling the engine to thread the new chain through.
On other engines the chain and drives can be buried deep within the block.
Cam belts are generally cheap and very efficient. They are also very suited to high RPM applications and have less mass implications. They do however require routine replacement. Belt replacement is normally very easy and straight forward. However in some engine/vehicle applications, such as the Fiat Coupe 20V & Marea 20V, there is little belt access because of the engine bay width and Fiat recommend engine removal to change the belt(s).
Belts and chains have their merits.
s130 is online now Reply With Quote Quote
Old 05-07-2010   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
extremely rare for chain to break but they do stretch and suffer tensioner issues.
Thanks Most Easterly Pandas thanked for this post
Old 06-07-2010   #6
Quote Originally Posted by T14086 View Post
Exactly- especially if not maintained correctly and with the correct spec oil. There's been several cases of Alfa 2.2 JTS (159/Brera) timing chains stretching due to customer's/non-Dealer's using the wrong oil at a service.
D4nny8oy is offline Reply With Quote Quote
Thread Tools
(T) 2009 Fiat Ducato 3 Litre, Cam Belt or Cam Chain steco1958 Ducato 4 08-12-2015 14:42
(G) 0.9cc seicento timing belt or chain ??? carmadrory Cinquecento / Seicento 4 30-05-2010 19:26
(T) 1.6 Another CAM Belt Problem? [exhaust CAM error] read123 Stilo 45 21-02-2010 18:16
(T) T-belt chain nikas Cinquecento / Seicento 3 11-10-2006 21:25
(T) timing belt/drive chain charlieboy Punto (Mk2/2b) 15 24-07-2006 17:16
