Hi, Welcome to the FF.
This is the reset procedure, however if your roof has suffered physical damage, it may not work.
OK; here's the full sequence taken from eLearn
The initialization procedure is illustrated below:
The initialization is completed at this point.
- turn the rotary selector knob to position '0' (fully closed)
- keep the rotary selector pressed (for longer than 2 secs): the roof closes
- wait, keeping the roof completely closed until the blind has clicked shut twice (Hard closing position and then returns to the Soft closing position)
- release the selector and press it again within 3 secs.
- keep the selector pressed until the roof (glass and blind) is completely open and then closed again
- release the selector;
in the case of repairs to or problems with the Body Computer or a break in the battery connections, the motor absorption may be 26+26 A max
The initialization process cannot not take place successfully if one of the following conditions occurs:
If the process has not been successfully concluded it should be repeated.
- The rotary selector has not been placed in position '0';
- The selector has been released during the manoeuvre;
- The blind operating button has been pressed;
