Re: Sky Roof stuck-Need help!
Hi mate, yep I had the same thing happen to my abarth took it to the Fiat dealer and they simply cleaned it and replaced a screw that had worked it's way loose. Mind you I do live in the Czech Republic where Fiat repairs are dirt cheap
Hi basically the problem is that the other day while having the roof open-i went to close it from being fully open to fully closed it got to about halfway and wouldnt budge so i opened it fully and then closed it kind of made a creaking pressure noise and then finally closed, then i got out and went to where i was going-however on coming back i noticed that the last blade eg, the one closest to driver had not met with the other blades full at first, although that is not the problem it seems that all the other blades have diagnally slanted at one side pushing it all out of sync and not just buzzes and crunches when going to open and doesnt open atall.it could be it has somthing stuck in the rails possibly like a seed from a tree? if so how could i get this out with it not opening? also how do you manually open and close the roof?
i have done a simple paint drawing to show the problem excuse the number of slats as i forgot how many it has. Many Thanks
[/URL][/IMG]
