Thread Tools
Old 04-04-2004   #1
Bulb Failure Warning light on dash
Hi I have a 2001 1.9 Jtd Stilo Dynamic which has a Indicator Bulb failure warning light and anoying "beep" every time I prees the brake pedal.
ALL the lights on the car are working fine !!
I have checked and read that sometimes the brake light sensor switch is to blame, can someone tell me where this switch is, do i need to remove all the plastic panel work in the foot well ?
Or is it likely to br another fault causing the warning to come up?
The car is over 2 years old so no more warrentty ( my dealer says) and my service light needs re-setting after I had the 36k service done at a Local Gararge rather than re-mortgage and go to Fiat !
Any help appreciated
Brad
Brad is offline Reply With Quote Quote
Old 18-11-2005   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Beep beep beep Bulb failure
Just in case anyone experiences this
Beep beep beep Bulb failure Rear fog
Beep beep beep Bulb failure Rr indicator>
Beep beep beep Bulb failure Rr brake light>
Well make your mind up! Which one? I check them out all working fine. Duh!
I remove the rear light cluster, not so bad as some cars. Check the bulbs- change them anyway- connect the electrics up back up before I put it back
Beep beep beep Bulb failure Rear fog. Jeez
Well there's only a few things that connect all that lot and it's got to be the actual connector to the rear light cluster making bad contact so I prised and pushed the connector contacts together a bit more and gave them a scrape to take off any crud and oxidation and hey ho no more errors. Must have been a bad earth contact. Well done Stilo!
Out on the road tonight
Beep! Oh no -wazzat?
Danger of Ice!
Hey Brill! Warnings that are actually true! Real warnings! Something useful- it works! I'm impressed!
Thanks flossydot thanked for this post
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 03-11-2006   #3
Deckchair5's Avatar
Re: Bulb failures left right and centre!!
99 Bravo 1.2SX
Old 01-12-2006   #4
Deckchair5's Avatar
Re: Bulb Failure
It triggers the bulb failure warning when the resistance is incorrect (broken bulb = max resistance, short circuit = min resistance) so I'd look for bad connectors and bad earths in that area
We don't have headlight failure warnings as the logic is "it should be obvious if they're gone". Would have been nice though as it might be just a dull day and not so obvious
99 Bravo 1.2SX
Old 16-02-2008   #5
Serbia
'Bulb failure' warnings, but everything seems OK?
One month ago I got this message for the first time, checked front right light and it worked. Message was gone after few seconds, so I didn't pay much attention to this. Same message apeared maybe two times per week until three days ago. Now message is on all the time. Today I also got several times message that right rear indicator is not working, but it's fine.
What could be the problem for this silly behaviour? I have 2004 model, and I thought that electrical silliness was cured until 2004.
yugo23 is offline Reply With Quote Quote
Old 16-02-2008   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: 'Bulb failure' warnings, but everything seems OK?
faiure system covers brake,sidelights & number plate lights.If they are all ok & working then you either have poor connection or wrong wattage of bulb.
Old 16-02-2008   #7
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
The system worked perfectly on my 02 JTD recently. (brake light failure).
Does it not indicate which side is the problem - with an arrow?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 16-02-2008   #8
Serbia
It does, but lights are working normally.
Old 16-02-2008   #9
Argonought's Avatar
An easy trick, if you don't mind a bit of work, is too swap the suspect bulbs right to left hand side etc.
If the problem switches sides then you know for a fact you've got an intermittent bulb but more than likely the problem will disappear.
Old 16-02-2008   #10
my drivers side headlight has blown twice and it doesnt give you any warnings on the dash ive also replaced to driver side brake lights although it does warn you that the stop light is out
belfast_lad is offline Reply With Quote Quote
Old 16-02-2008   #11
Deckchair5's Avatar
Your Stilo isn't beng silly, it's being much smarter than you give it credit for
It's telling you the resistance is wrong and identifying exactly where the problem is, even before you notice or experience a fault and you can bet that it's dead right
So as T1 says, it's either a wrong or duff bulb ( but then i'd expect it to happen every time you started) or a poor contact point in that circuit
It's one of the first jobs I had to do on a Stilo
Headlights aren't part of the bulb check system as it assumes you can spot that easily on your own
99 Bravo 1.2SX
Old 16-02-2008   #12
Serbia
Quote Originally Posted by Deckchair5 View Post
It says : Front right
Old 16-02-2008   #13
Deckchair5's Avatar
It'll be a poor contact or connection at your front right sidelight then
99 Bravo 1.2SX
Old 02-04-2009   #14
re: Bulb Failure Warning light on dash
Did you ever find a resolution to this issue? My dealership told me that I would have to buy a whole new headlight unit which I think is Bull!!!!
Rocky D is offline Reply With Quote Quote
Old 02-04-2009   #15
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
Try replacing the bulb. Even if the bulb looks fine, works and lits up while braking, it's worn, and produces a signal that exceeds the body computers fault tolerance (voltage or resistance I guess). Mine has also been acting like this last year, so I just replaced the bulb and it's been fine since. If you compare the bulbs you will see the metal inside (wolfram?) is pretty worn and propably creates a higher resistance than allowed. Just a thought.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Thread Tools
(G) Bulb Failure warning light!! dannyjohnston Stilo 13 14-06-2011 08:25
(G) yellow bulb warning light on dash xnatty19x Punto (Mk2/2b) 4 07-07-2008 13:58
(G) Stilo bulb failure warning system Argonought Stilo 5 04-02-2008 10:17
(T) Road light Bulb failure warning system.. Andy Monty Grande Punto 6 27-08-2007 22:18
(T) Bulb out warning light Craig-m Punto (Mk2/2b) 5 06-03-2007 22:45
