You'd have to compare it to other Fiat group clutches to see which matched, but there will be an uprated clutch available. The 1.8 16v,, 2.0 16v, 2.0 20v and 2.4 20v as well as 1.9 and 2.4 diesels are all interrelated in terms of being part of Fiat's modular engine design. That covers both Alfa, Lancia and Fiat cars. This means there isa very high likelihood of clutch interchangeability, and fortunately their are much more powerful cars out there that are likely to have compatible clutches
The interchangeability will depend on which mechanism the clutch uses. Most use a pull-type, and there are a wide selection of uprated clutches as the Fiat Coupe 20V turbo uses one, and the Alfa V6 2.0 turbo, 3.0/3.2GTA also uses the same clutch type (the latter GTA clutch being better). Even the old Lancia Delta Integrale clutches are similar.
But it might be a push type, I think the 2.4JTD 20v as found in the 156 has a push-type as the clutch design is very different and I think the gearbox main shaft spline is also different.
So either the 2.4JTD 20v or the GTA clutch will fit I would say and would be uprated compared to your stock clutch. If you go to a Fiat dealer that has both types and yours in stock you can probably easily figure it out.
You could also look at 1.9JTDs on the alfa side as they have the more powerful engine in the first place.
BTW the juddering might be part of the problem - if the clutch is not making good contact with the drive plate or the flywheel then it will not hold as much power, and in either case I would suggest you get the flywheel skimmed when you get the clutch changed.
