| stilo sunroof not working I have a fiat stilo 1.6 active with a panoramic sunroof. I have had it 3 months and the roof is still not working. I have replaced the motor and put a new switch and nothing! Any suggestions please!!
| Re: stilo sunroof not working Not sure if it's anything like my old Punto's roof (I know there are differences as yours is multi-panes). Anyway, the Punto had a slot to manually turn it if the motor has jammed or anything. Mine broke by the carwash drier pushing out a small pin stopping the mechanism from going back more than 2cm. I found pusing back in the pin solved it.
__________________ Ex Teseo Blue Punto 2000W Mk2 ELX 8v Owner. 4.5 years and 60k miles worth of Punto joy. If you see W871TBL, let me know... | |||
| | #3 | ||
| Re: stilo sunroof not working Hi, thanks for your reply. The sunroof does not open at all, not even with the emergency 'key' located in the switch box. It has got everyone baffled!
| | #4 | |||
| It's about GO! not SHOW! | Re: stilo sunroof not working
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #5 | ||
| Re: stilo sunroof not working I seem to remember (I could be wrong) when mine went a bit odd that there is an overload sensor that stops your kids chopping their heads off in the sunroof. Maybe it's this that's causing the problem. Surely you need to check if volts are getting to the motor/switch before changing them ? The whole roof was changed in my 3-door Stilo under warranty after a fault. I think the list price of the sunroof alone was about £1200.
| | #7 | ||
| Re: stilo sunroof not working Motor and switch were changed by garage i bought it from, i wouldn't have paid that kind of money without being sure. Also an electrician has looked at it. In the hand book it says about the anti trapping device and tells you to press some buttons which doesn't work. When i press the circular switch in the middle it clicks! Does thast mean anything?
| | #8 | ||
| Forum Moderator | Re: stilo sunroof not working Anti trap is in motor. You are talking about the initialization procedure,hold (push) button in until a cycle is carried out & 2 clicks heard,then press again.
__________________ IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER! | ||
| | #9 | ||
| Re: stilo sunroof not working yes, thats the one. Unless i did it wrong, it didn't work.
| | #10 | ||
| It's about GO! not SHOW! | Re: stilo sunroof not working This is quite a long thread which might help you http://www.fiatforum.com/stilo-techn...hlight=sunroof
| | #11 | ||
| Re: stilo sunroof not working Have read all that and tried the button thing but it just clicks! How do you lubricate it when it won't open?
| | respect | Stilo | 54 | 09-10-2006 20:15 |
| looking for a STILO skywindow (sunroof) | 184 | Lets Talk FIAT | 1 | 03-10-2005 18:00 |
| Who here misses Abarth engines? | Reaper | Put it to the Vote... | 27 | 21-09-2005 08:47 |
| | JR Graville | Stilo | 108 | 12-09-2004 16:11 |
| | stilo | Stilo | 35 | 19-04-2004 21:40 |
