Posts: 5 Thanks: 0 Trader Rating: 0 | gas cut and engine Died when low gear My engine has indicated a fault with a spanner than when i start the engine, it doens;t hold the gas and after few "REV" the engine will storw Any 1 can help Also my A/C is very Hot Stilo 1.6 5door THX
Posts: 5 Thanks: 0 Trader Rating: 0 | Re: gas cut and engine Died when low gear Sorry I think i didn't give enough information I drvie 52 Active 1.6 When i start the car it "rev" and very low gas, if you leave it in neutral gear a about 20 secounds, it will strow, even sometimes when i turn in low gear it strow as well. Also I hv changed the Spark Plug today, but it is the same, Is it the coil problem? Should oi changed the Coil?? Thanks
| | #3 | ||
Posts: 24,779 Thanks: 772 Trader Rating: 0 | Re: gas cut and engine Died when low gear Time to take it to a dealer for dagnostic.
__________________ | ||
| | #4 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 | Re: gas cut and engine Died when low gear I hv They said i need to replace the air bag and the fule pressure sensor is begin fault But thry are nth to do with my engine...
| | #5 | ||
Posts: 24,779 Thanks: 772 Trader Rating: 0 | Re: gas cut and engine Died when low gear fuel pressure sensor is,but I doubt if that is the problem.
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 21:20 |
| | arseofbox | Bravo / Brava | 13 | 29-03-2006 17:24 |
| | xlilmx | Cinquecento / Seicento | 13 | 22-01-2005 13:57 |
| | HP. | Cinquecento / Seicento | 0 | 31-12-2004 00:17 |
| | dimension8 | X1/9 | 3 | 18-12-2004 11:32 |
