The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Closed Thread
Old 20-06-2006   #1
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
CONNECT Nav Issues - Please Read This
Due to the high repetition rate of posts and threads regarding problems / issues / queries with the Connect Units, I've decided to bring them all together in this sticky.
  • POLL for views on GPS accuracy of different versions, click here
  • FTP Access to obtain Setup Discs or Map Data, click here
  • For information about software updating the unit, click here
  • For information about installing the unit, click here.
  • For information about functionality of the unit, click here
  • For information about connecting an iPOD to the unit, click here.
  • For faults and problems - USE THE SEARCH FACILITY FIRST! If then you have no luck, please post in the Technical section.
  • For the ongoing discussion about the unit resetting track position when switching off, see this post.
  • For a list of Voice Commands, please see this post.
  • To solve the issue with a used Blaupunkt IDC-A09 not playing when installed, see this thread.
Rebooting the Unit
If the unit is experiencing problems whilst driving, a reboot may solve this issue. To reboot the unit without turning the ignition off and back on, simply press "Setup" four times.
Hidden "Service" Test Menu
There is an inbuilt menu in the Connect Nav+ unit that allows the user to ensure various modules are working, and that the speakers, antennas and GPS/GSM systems are functioning normally. To access this menu, do the following continuously and quickly:
  1. Press "Setup".
  2. Press a "Connect" softkey (i.e. push either button 10, 11 or 12 of the 12 buttons along the bottom of the screen).
  3. Within a second, press a "Connect" softkey (same as above) 3 times repeatedly.
  4. Press "Enter".
  5. Scroll down to the newly appeared button "Service", and press "Enter".
Turning Screen Off Whilst CN+ Is In Use
Simply push and hold down "Main" for about 5 seconds. Press any function button (e.g. main, nav, audio, tel, map) to turn it instantly back on.
Thanks, and happy foruming!
Rich
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
The following user says "Thank You!" to Rich for this useful post:
alanh (04-09-2008)
Closed Thread
(T) Connect Nav+ users, please read! Rich Stilo 38 27-06-2008 12:05
(T) Connect Nav issues The Crig Stilo 2 22-05-2008 09:24
Connect NAV+ issues jw54 Ulysse 15 21-03-2007 16:36
(G) Connect Nav+ Functionality Issues Rich Stilo 10 31-08-2006 11:51
(G) Anyone with Connect Nav + please read! Rich Stilo 14 02-12-2005 19:15
