The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 12-03-2006   #1
Trader Rating: (0)
Wheel nuts
Questions....?
Everyone thats fitted replacement Fiat Alloys, have you used the old wheel nuts?
Locking nuts! Did you go to a Fiat garage and get Fiat ones, or did you go to Hellfrauds and get compatible ones?
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 12-03-2006   #2
You can't fool owls.
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated! United Kingdom
Re: Wheel nuts
Depends what wheels you are fitting and what wheels you had previously. Always best to get the correct bolts rather than wobbly ones, unless you have to in the case of 100pcd alloys.
Steel wheel bolts on alloys and vice versa are a big 'no no'.
'Not everything in black and white makes sense'
Hellcat is offline
Old 12-03-2006   #3
Trader Rating: (0)
Re: Wheel nuts
Well i'm going from 15" Fiat Steelies, to Fiat 17" Claws! So i'm assuming the orginal bolts will be fine, no need for wobblies!
StiloBoy is offline
Old 12-03-2006   #4
Hellcat's Avatar
Trader Rating: (3)
Re: Wheel nuts
Hellcat is offline
Old 13-03-2006   #5
Stilo_ste's Avatar
Trader Rating: (0)
Re: Wheel nuts
Why is that then chap? Are bolts that are used on steel wheels not compatible with alloy wheels? or is the length different for any difference in material thickness at the centres?
Say that, as I used the original bolts when I changed from steels to alloys, fitted fine. Haven't had any negative effects.
Have I done something wrong, and do I need to go and buy some new bolts? What is the difference?
Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS.
2004 1.8 Vauxhall Vectra - 5 Door
1974 3.5 V8 Triumph Stag - 2 Door
Stilo_ste is offline
Old 13-03-2006   #6
Veracocha
bozzy's Avatar
Trader Rating: (3)
bozzy has donated! United Kingdom
Re: Wheel nuts
Same here on my last Stilo. In fact, the Fiat garage did it for me and never mentioned the difference in materials for the bolts.
bozzy is offline
Old 13-03-2006   #7
Hellcat's Avatar
Trader Rating: (3)
Re: Wheel nuts
I would have thought that the steel wheels would be much thinner than the alloys. The spare on my tipo has a thick spacer attached to it to make up for the thickness of the alloy.
I would check using the EPER that the wheel bolts are not different as every steel wheel bolt I have seen has been shorter than the alloy equivalent.
Hellcat is offline
Old 13-03-2006   #8
wotnowarninglight's Avatar
Trader Rating: (0)
Re: Wheel nuts
I have Coupe wheels on a Stilo and needed Coupe wheel bolts & lockers as Stilo bolts are shorter. I used all genuine FIAT bolts & lockers. My local FIAT dealer did order a set of Stilo locking bolts, their rational was that these would be easier to sell on if they didnt fit. Stilo lockers look Identical to the Stilo steel wheel bolts, in terms of seat/pitch & length and assume are the thing to use if you are fitting genuine Stilo Alloys.
Technical bit: diameter pitch length
Stilo Bolts = 12 mm 1.25 25 mm
Coupe Bolts = 12 mm 1.25 34 mm
Genuine FIAT lockers should set you back around £25 incl. VAT - Hellfrauds McGuard lockers £ 32.99 - did spot a set that would do Stilo alloys but nowt in McGuard long enough for Coupe application!
EDIT: Notice from my notes that FIAT dealer did quote me for bolts for fitting Stilo alloys also (made out of a different material to the steel wheel bolts perhaps?) so would advise you to check with FIAT unless any techs here who can confirm/advise???
Black 115 JTD, 16' 16vt Coupe alloys & debadged
+147 Cruise Control NOW with added Millers Diesel Power Sport 4
wotnowarninglight is offline
Old 14-03-2006   #9
Trader Rating: (0)
Re: Wheel nuts
So any of the Active spec Stilo owners want to answer this? Anyone thats gone for Steelies to genuine Fiat Stilo Alloys please! As your the only ones that can answer under these circumstances!
StiloBoy is offline
Old 14-03-2006   #10
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Wheel nuts
IMO I dont think you nessesarily have to worry what spec the car is cos in the handbook it tells you the ET /offset of the wheels you just need one member to give you the bolt length and that I would have thought would be that I can tell you that i read the other day that bolts should turn between 6 to 8 full turns into the hub to be legally safe well i never knew that but we learn something new every day
PNL is offline
vB code is On
Wheel Nuts minimad99 Stilo > Technical 5 27-05-2005 08:20
3 wheel nuts in all 4 wheels, is it safe? spongmonkey Cinq/Sei > Technical 20 09-01-2005 23:14
Sei Sporting alloy wheel nuts needed andy279 Parts Wanted 2 05-08-2004 07:21
new Wheel nuts for sei sporting andy279 Cinq/Sei > Technical 1 21-05-2004 20:36
Check those wheel nuts!!! 2.0 20v Leisure Lounge 8 06-05-2003 00:13
