| | #16 | ||
| Re: carbon fibre bonet rite people ive got a company that will make a carbon fibre bonet for the stilo they need 10 people to show interest buy putting £100 deposit down on a bonet for there car. you can have any design with in reason (vents, bad boy, etc...) there asking a full amount of £400 from each person. thats including the £100 deposit. so its £400 which i make only about £20-£30 more than off the shelf 1's for other cars + ul be the first to have a cf bonet on a stilo any 1 interested pm. for any further info pm. this is also open to outside uk
| | #17 | ||
| Re: carbon fibre bonet So a part from the obvious looks point of view, what other benefits could one get from a CF bonet. I know its a lot lighter than the regular steel one but would you be able to feel it while driving the car??? How much does a steel bonet wheigh?? How bout a CF one??? By the way, if i could afford it i'd be putting myself down for one of these!!!!
| | #18 | |||||
Q:What is advantages to use those parts? A:The benefits of Carbon fibre are many. For our hoods some of them are: Attractive custom appearance Added vehicle value Light weight - approximately 1/3 the weight of most factory hoods Improved vehicle performance Corrosion resistance Q:What is the average weight of hoods? A: Hood weights differ depending on the size, but the average is between 12-15 lbs. Typically density of steel is 7 g/cc, for carbon it is 2 g/cc so our hoods are approximately 1/3 the weight of a comparable steel hood. We have designed an Ultra-light full-framed hood for a Honda Civic 2003, which weighs only 5 1/2 lbs, while our heaviest hood is for a Volvo 850 at 18 lbs vs. 58 lbs for factory. Q:Can carbon fibre products be made as strong as steel? A:Yes.Carbon or Graphite fibres are a man-made material which is 3 times stronger and 5 times stiffer than steel. This enables us to produce products that are much lighter but the equivalent strength of steel. Kevlar is lighter than carbon fibre and steel but not as stiff as carbon fibre. This makes our "hybrid" material of Carbon/Kevlar even more appealing, not to mention the available colors. Q:How durable are these parts? A:The Carbon fibre can last longer than any metal because it is resistant to fatigue or corrosion. We have developed our own exclusive blend of UV stable laminating resin for use in all our products. Our resin is ultra-clear, has a UV rating of approximately 7000 Hours /1000 Hours is equivalent to 1 year in Miami climate/ and has a very high impact resistance. Generally, a falling tree branch of a stray baseball would not damage our carbon fibre hood but could leave a steel hood with a dent. hope that answers ur question
| | #19 | ||
| Re: carbon fibre bonet my mate would be able to make you one!! you would have to provide the oe bonnet, he would cover it in masking tape and make afibre glass skin the make the carbon fit over the fibre glass then butcher the oe bonnet so that the carbon can fit over the oe skin and put it back on and re-aline it!! your looking at around 800 quid this way would garentee a good fit but actually weigh more than the oe bonnet but if its just for looks then that wont bother you too much!!
__________________ 05 broom yellow stilo abarth (manual) now for sale......... check out the classifieds section for a bargin | |||
| | GSEBravo | Bravo / Brava | 14 | 25-12-2006 20:38 |
| | Red Cinq Sporting | Cinquecento / Seicento | 19 | 16-12-2005 23:02 |
| | 1.8Stilo | Stilo | 8 | 23-10-2005 22:33 |
| | Body Stylist | Punto | 0 | 26-02-2005 13:27 |
| | simon2189 | Cinquecento / Seicento | 3 | 22-11-2004 01:36 |
