Thread Tools
Old 3 Weeks Ago   #1
Denmark
Fiat Stilo ECU change error
Hello everyone
First just to let you know im new here so bear with me.
My problem is that i have bought a Stilo 1,6 from 2002.
After a while it startet shutting down and writing errors on just about everything.
After trying everything I read here that the ECU could be the problem. And indeed it was.
So I read all the forums I could find and ended up exchanging my 5nft1 to an 5nft9 ECU whitch I have read here schould be okay.
Here's my problem.
After changing it the engine starts and runs perfectly BUT all lights are on in the dashboard. Even the immobilizer is constantly on even when driving.
I have followed the instructions given with the ECU but nothing helps.
It like the dashboard has no connection to the ECU.
Enyone that can tell me if the ECU is defect or is this a fault from my side.
Racercmus is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Dean
Zeewulf's Avatar
Zeewulf has donated!
Re: Fiat Stilo ECU change error
Did you do a Proxi alignment after putting in the new ecu so it learns what it is talking to ?
Blue & Me Website - http://www.blueandme.net/blueandme/index.aspx/
Zeewulf is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Denmark
How do i do that?
In the instructions it said I should mount it and put it to ignition, then i should depress the clutch and start the engine. After this i let it heat up and then rev the engine to 5000 for 2 seconds 3 times.
Old 3 Weeks Ago   #4
Denmark
Quote Originally Posted by Zeewulf View Post
Which software do I need in order to do the Proxy alignment?
Is there any free software or do I need Multiecuscan?
Old 3 Weeks Ago   #5
Dean
Zeewulf's Avatar
Multiecuscan and the correct cables can do it, but check to see if your local garage can do it first or even explain the problem to the seller of the ecu and see what they suggest as they might have come across this problem before (best to ask before spending any money).
Likes g8rpi liked this post
Old 3 Weeks Ago   #6
Proxy align would have been my first thought too....
Registered Alfaholic
Current cars - Stilo Abarth (let's not mention the Audi)
Previous: Fiats: Uno, Tipo, Brava (1.8 ELX), Marea (2.0 155); Alfas: 156 (1.8TS), 166 (3.0 V6), 156 GTA, 156 Sport (1.9 JTD M-Jet), 159 Lusso (1.9 JTDM), 147 Lusso (1.6TS)
Artermis is offline Reply With Quote Quote
Old 3 Weeks Ago   #7
Denmark
Okay so I have now contacted the seller and they also mentioned proxy alignment.
My local workshop would like to help but doesn't have the equipment to do so. Can a Fiat dealership do this cheap or is my best chance to do it with Multiecuscan.
Last helping hand for now
Do you have any links to the correct cable and the best site for buying Multiecuscan.
Old 2 Weeks Ago   #8
Dean
Zeewulf's Avatar
Quote Originally Posted by Racercmus View Post
Multiecuscan is 50 euros direct from guy who makes it, you'll need a laptop and cables:
http://www.multiecuscan.net/
http://www.ebay.co.uk/itm/ALFA-FIAT-...sAAOSwGOZTxWZ2
Fiat could do it but it won't be cheap and if you own MES (MultiEcuScan) you can then do all your own fault codes and change settings on some things etc.
Just MAKE SURE you model/engine is listed on the MES website BEFORE buying !!
Thanks Racercmus thanked for this post
Likes Racercmus, g8rpi liked this post
Old 2 Weeks Ago   #9
I would go with the MultiECUScan option personally.
It might be a little bit more expensive than the dealership, although the software costs roughly what an hours labour would here in the UK, so there is very little in it.
Of course even once you're finish you'll always have the software and the cable, just in case anything crops up in the future - so you're saved from the hands of garages and dealers should anything else happen.
Old 2 Weeks Ago   #10
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Artermis View Post
@Racercmus
I agree with Artermis and Zewolf, Use Multiecuscan.
I've bought from the sellerer Zewolf linked to, but don't think they post outside the UK. Look for a similar set on your local ebay or Amazon. Make sure it says modified for Multiecuscan, the very cheap ones from China have a design fault.
Note for your car you can connect to the ECU with the unregistered (free) version of MES so you can make sure everything works before you pay the €50 registration fee. Proxialignment need the registered version.
Robert G8RPI
g8rpi is offline Reply With Quote Quote
Old 1 Week Ago   #11
Romania
your ecu was plug and play?
sanji961 is offline Reply With Quote Quote
Old 1 Week Ago   #12
Yes to a point... but needs to be aligned by mes as this thread clearly states
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is offline Reply With Quote Quote
Old 1 Week Ago   #13
Quote Originally Posted by dtimmins1985 View Post
I would suspect if it's been bought from a specialist it's either been virginised or had the immobiliser removed. Lets face it, with the immobiliser light on the dash the thing shouldn't be running.....
Thread Tools
(T) EDC15C7 Fiat Stilo damaged ECU & immo new ECU virgin/solder MatesCZE Stilo 1 13-09-2014 10:02
(T) stilo abarth ecu change Jamescollins1 Stilo 3 26-01-2014 21:27
(T) Stilo ECU change gambitrl7 Stilo 5 21-11-2013 11:28
(G) Ecu, error codes - fiat punto 2002 sandylobban Punto (Mk2/2b) 12 09-09-2013 19:49
Fiat Specific ECU EOBD OBD DTC Error Codes List (Full) gkoryt Tech Talk 3 22-03-2011 00:08
