Lamps by Post - For all your lighting needs
Thread Tools
Old 3 Weeks Ago   #1
Barry1955 has donated!
Stilo 1. JTD n/s noise after nw parts fitted
Hi guys,
Hoping someone out there has experienced this problem.
Just had new springs, lower arms and front links replaced on my 1.9 JTD 3 door Stilo sporting ( 2007 ) to get MOT.
Car now has a rattle/ squeak noise from nearside front suspension, that takes 10/15 mins of travel to start. It`s different to noise of broken spring ( had 4 now ! ) and doesn`t occur on bumps or sharp turning, only whilst driving on ` normal ` smooth roads.
Taking car back to garage tomorrow, but fear response will be " we couldn`t hear anything "
Any ideas ?
Barry1955 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Stilo 1. JTD n/s noise after nw parts fitted
Where is it coming from.. the top or the bottom?
If you had new springs then they would have had to dismantle the damper/spring assembly and that might be a candidate for being re-assembled with a slight misalignment in the re-used parts that were used to sitting in a particular way and worn "together". They'll bed in as they adjust to their new position.. but a few squirts of grease in the bearing/top mount will help.
If it's the bottom then the arms' bushes are the only thing that can squeak. Again, a spray with something oily like white grease will quieten them down. I doubt the garage has mis-fitted anything.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Thread Tools
(T) Stilo 1.9 JTD MW - Engine Noise Pyroadi Stilo 1 12-10-2007 19:07
(T) 1.9 JTD - could Fiat / Alfa parts be fitted from higher output engines? Ben H Grande Punto 0 29-04-2007 11:30
