Well... I finally got to the bottom of the nasty water leak coming from the water pump... #dontlikegaragistes
It turns out that Le Garage that fitted me a new water pump (to solve a leak at the spindle that started whilst Gerrard was on Le Peripherique in Paris... 34C and stuck in the traffic jams did for it...) managed to nick the edge of the rubber o-ring on the machined face of the engine block.
Ever since then it's been leaking .. and obviously it gets worse when the system is hot/under pressure... so I had to dismantle it for a look, since I can't afford another holiday in France and therefore the prospects of taking it back to be fixed/done properly are zero.
It's not all doom and gloom, since I fitted a new tensioner and a cam-belt whilst it was apart.. and then a new aux belt tensioner to finally cure the annoying squealing it made just off idle... but since the water pump turned out to be a nicked o-ring, rather than just a loose bolt etc. as I'd hoped, I could only re-fit the pump with a load of sealing gaskety goo around it and hope for the best.
But the goo hasn't worked and the pump is leaking again.
This time I have a new O-ring (it came with a new pump attached, c/o fleabay) but I dunno if I have the energy to swap it out again right now.
Plan B is just to stick Radweld in the system and see if that cures the dripping... but I dunno if that will work. The radaitore is new too, so I'm partly reluctant to stick something in there that may start to clog it up in some way.
The o-ring itself had a fair piece missing from the outer edge and the gaskety goo I used (Blue Hylomar) obviously hasn't sealed it. Does Radweld block such gaps or does it not stick to rubber etc.?
I dunno why the Hylomar didn't fix the leak.. normally it can hold back anything. Is Hylomar glycol resistant? Would silicone gasket have been a better bet?
Plan A is to fit the new pump (Fiat OE) with its new gasket.. but if I can do it later c/o a temporary fix, I may be tempted..
Ralf S.
Ralf S.
