bigbertieman
- Mar 14, 2017
- 4
- 1
Ist Fiat might be last the way things are going.
Started couple months ago as a slight misfire thinking needed a service.Then really misfired and then driving home misfiring then temp gauge rising, EML flashing on and off and car eventually overheated.
Result Head gasket gone head warped, cylinder head skimmed and re-seated on two cylinders also,water pump replaced timing belt kit done also.
Injector replaced orig fiat part.One massive bill later and guess what still misfiring
Auto elec checked coil and pack ok faults coming up intermittent 3 cylinder misfire and also O2 sensors both of them.Sent away emu away verdict the connectors are loose and need re-soldered but after testing no intermittent 3 cylinder fault gave the go ahead to re-solder pins and send back to refit. If still running like a dog I am out of ideals and so is the independent Fiat garage any views apart from the obvious
compression test across 4 cylinders 180
auto-elec checked wiring to coils ok
new injector replaced
spark plugs checked and new
