Dear FIAT Stilo Gurus!
I need your help once more - I have to check the injectors in my 2002 Fiat Stilo 1.6 16V Dynamic, because @ the D81 connector one showed infinite resistance. That's why I need access to the injectors.
So right now my actual status:
- I removed big plastic air chamber, removed the two T30 size torx screws holding down the fuel rail, and it is free in theory. The problem is, that I have no idea about the next step - so how exactly should I remove the single fuel manifold (fuel rail) with the 4 injectors on it... The big metal inlet manifold is still in its place and because of that there is not much space left between the cylinder head and the metal inlet manifold for squeezing out the fuel rail + injectors... I tried to "grab" the fuel rail at around the valve (gearbox side) and at around the fuel in line connection part (timing belt side) and pull the whole thing, but no luck, and I am scared, I don't want to screw this one up.
Please some of you who actually had been able to achieve this task reply to this message and help me with some useful advice!
Thank you very much in advance!
