Thanks for all your assistance on this, I now having working fog lights!
It turned out to be both bulbs blown, I tested the fuse first, which was ok, as this was easiest, then unclipped the panel behind the fogs on the drivers side, what a pain just to get the cover off as the washer bottle and wiring loom for the cluster are in the way, I presume the wires unclip? I couldn't figure out how!
Cover off now I need the fingers of an orangutan!! just to get at the bulb, all by feel as you can't see anything. It seemed my bulb hadn't been fitted properly, someone had tried and given up by the looks of it!?
Anyway the wire clip just fell off, managed to re-secure it, why can't they be fitted like other cars where it just unclips and swings away but stays attached?
It seems a very odd place to have fog lights!? It's basically just another main beam bulb but aimed further down, usually fog lights are placed much lower down the front. Only got to try and put the covers back on!!
