Technical Strange sound
Tomasso72
Hello everybody,
I would like to ask some help for you...
I have a Stilo 1.4 and few weeks ago I experienced a strange sound into ribbed belt drive system. When I put off the belt, this sound is out.
I have changed climate compressor bearing in the belt disk, belt tensioner bearing (not the complete tensioner, only bearing) and crank shaft belt disk. This sound comes in around 1400-1600 rpm and it seems like a woodpecker knocks the wood :) If I rpm speed up or slow down the sound follows the rpm changing. Beyond the range 1400-1600 isn't strange sound.
What can the solution? what have even I change besides that?
Thanks in advance for your replies,
Tomi from Hungary
Thanks for everybody, it is a very good group...Lots of helpful members, etcetc...I hope, I will find a solution about my problem with myself... Here won't find helps, it is sure.
Bye
