OK, so I tried everything, and I still cannot connect to AIRBAG ECU via Multiecuscan.
I have a Chinese VAGCOM cable, and with that I am able to connect to ENGINE ECU, so all is fine.
I have original ELM217 cable, same situation, but MES says when I try to connect to AIRBAG ECU: You'll need Vagcom or obdkey to connect.
Now I bought a simple RED adaptor cable (without extra thingy bit to 12V stuff - only OBDII male-female), put that in, other end to Chinese VAGCOM, and MES still can connect to ENGINE ECU with this combination, but when I try the woeful airbag errors code to read: connection timeout, check cable/adaptor/port settings...
What am I doing wrong? Is my adaptor crap for the Stilo? Please someone help me!
If needed, I will upload photos of pinout settings from Chinese VAGCOM cable.
Thanks in advance!
Thanks in advance!
