Hi
I have a 2004 Stilo 1.4 that's done 145k. Until recently it was averaging 40mph, then for a week or so I noticed the car needed the accelerator pressed further to get the revs. and speed up through the gears. I also had a feeling I was using more petrol, so I scrolled through the indicators to average consumption and was shocked to see it had dropped to a measly 31mpg.
A few days after this the yellow dashboard light came on and stayed on, so I used a cheapo. meter thing off Ebay to find the fault code(s). There were three:
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0505 Idle Control System Malfunction
and
P1172, which I can't find on the error code list. Maybe because the Stilo 1.4 has a Punto engine.
I cleared the errors and the warning light has not come back on. The car doesn't have any misfires, the revs. are steady when idling and it drives smoothly once it consents to reach 30mph+, so it's still getting me from A to B in reasonable comfort, but losing 10mpg is becoming expensive.
I'm not sure what is causing the fuel economy problem. I presume the first is a Lambda sensor, which is annoying as the cat. and the sensors were replaced less than 18 months ago, but I'd rather not go spending money getting this fixed if the other codes indicate other expensive things that need replacing. After all, the car is only worth a few hundred quid, so you have to draw the line eventually.
Any ideas? Thanks.
and
Any ideas? Thanks.
