dtimmins1985
Established member
Afternoon all,
So then guys, was going to get the car on a power run at RS Tuning at end of this month but.. a big but - them plans have been set back.
I need to choose some new discs and pads.
The current discs seem fine but... this car is new to me and I want to change both discs and pads this time round so i know they are both brand new.
Whats prompted me to want to change them so soon?
Well, on Saturday evening i had a car full - two of the people in the car are about 20 - 30 stone each, me and the other two are like 10 - 12 stone each, you can imagine the load my car was under.
I was on the motorway, didnt realise the speed i was doing! looked at the dashboard and thought feck! i had hit tripple figures with 90+ stone in the car... i backed off the gas and gently pressed the brakes, about 1 second into the breaking and slowing down to 70, i hear a big bearing like noise - whirring like mad, i let off the brakes and it stopped, gently pressed again and it came back... decided to keep the speed low due to the weight in the car and needing to get her back home safeley and the noise went away.
Since this episode - the noise has not come back, i havent had that much weight in the car either, i have tried heavy braking to see if the noise came back but nothing, it seems fine.
On closer inspection yesterday morning - i notice that the pads all round (each corner) seem on the really low side, probably have about 1 - 1.5mm left of thickness, discs have a little lip but nothing major - have had worse.
So, i was wondering - was it the shear weight, speed and low pads that could have caused this, i did suspect something may have lodged in between the disc and pad but that would of caused a groove or some markings and there is nothing there.
Can anyone recommend a good brand / model
Also, anyone tried green, yellow pads and the grooved discs?
Any advice, ideas and thoughts welcomed.
